my blm is at 142 seems a bit high, cheacked for vac leaks everything seems fine dont know how to properly check the egr area since i have a rjc pp which blocks it from the intake and i also had cut of the egr port on upper plenum..other than that i also noticed a very fine hairline crack on driver header, barely noticeable i noticed when i couldnt burnout with the 6765 it just wouldnt brake boost off the line it would stay @ 0 psi when i would try and brake boost it the car would just raise up a bit in rpm and not do shit, im thinking the header is the problem anyone got any other suggestion 142/145 isnt way to far off...?
