BLM Question
1turbo6
my BLM's are at 128 at idle and soon as I crack the throttle they go to 138. what would cause the car to go lean?? I also have an older translator and lt-1 maf I took off another car, where should I set it 10% rich or 10% lean to help fatten the car up?
I'm guessing your chip is set to open loop idle :frown: which accounts for the 128 idle value in that cell.
As soon as you crack the throttle you move to a different cell.
BTW 138 isn't that bad at all. Any drivability issues? If not don't worry about it.
