#1 Used 3.8 109 block out of my tta ran good when taken out $350 pickup only
#2 Used VIGALANTE single disc lock up TC. Lockup worked good but didnt stall right most likely needs a rebuild. $100
#3 BRAND NEW roller cam from full throttle Revolution XR2 w/morel lifters, comes with thrust button and comps double roller timing 210/215 chain. $660 going a diff. direction.
#4 37# injectors and making tt chip make an offer
#5 stock good working turbo Make an offer
#6 chrome turbo shield "MAO"
Also have stock piston/rings/rods/crank/caps/cam/timing chain and gear...... if you need somthing just ask if i have it and what your willing to give. all used and good except the crank thrust surface is bad. This is off a tta
can get pics if you need them
