SignUp Now!Is this a true hot air block #25514290 . If so some info on it would be a treat thanks
Casting number is on the bottom of the block, drivers side near the transmission. Good luck. Brad
Yeah thats where i found it. I think im off a number or something thou..
Freeking idiots put a 79 block toghether with 84 hotair parts on it.Well looks like back to the drawing board with this crap,well basically it is almost the same block rightYour not of a #, It's a 1979 turbo block.
That is indeed a Hot Air block casting. I have 2 of them here in the shop. Both out of 1984. Both 14 bolt oil pans. You could always check the VIN that is stamped on it. I bet you would find that it starts with a 4EHXXXXXX.
I didn't even bother to click on the GNT-TYPE link. From what I've seen a 79 casting would start with a 12 or 2550.
Just like the 109 blocks the Turbos and NAs used the same casting numbers.
Drivers side. Back on the bell housing flange. The is a flat area where a partial VIN is stamped.
