WarWagon
Caustic Cacophony
- Mar 10, 2007
What kind of mods are you talking about? The gaskets or things on the "Hanger 18" list like jet extensions and the like?
Any opinions on the hp limitations of it?
Mainly the throttle shafts and plugs in the meteing blocks need attention. The throttle shafts will leak fuel out and meter block plugs can blow out under boost. Oversized needle&seat, nitro floats, float bowl equalizer all should be used too.
The hp potential is limited to how much fuel can be flowed through the carb. A small venturi carb will pull fuel much easier even with a weak booster signal.
