http://www.turbobuick.com/forums/alcohol-nitrous-propane-tech/147348-tuning-alkycontrol-kit.html
Its a sticky for a reason. Please read and read.
Your first step in tuning is with a scantool make sure the BL numbers are correct on the motor. This will verify your fuel pressure is setup properly.
There is no way the BL can be correct with 60 PSI base fuel.
What happens is the computer see's the car is very rich and pulls out as much fuel as it can to try and compensate for it. Next is you pump a bunch of boost into the motor with a leaned out curve.. and kaboom there goes the gasket.
Now what has happened is the high fuel pressure more than likely has been washing down the cylinders and getting into the oil. So your oil is trashed, you detonated it with trashed oil=bearings are trashed, and you milkshaked the motor=bearings trashed.
Yes pull motor.. flush out the cooler if you run one.. your turbo may also have gotten hurt if any metal in oil.
All this over setting fuel pressure way too high.
Lastly.. the motor having Champion heads moves more air and makes more power. And is touchier to tune. This motor should not have ever gone this high in boost without perfect tuning at lower boost levels. Especially with junk 91 octane gas.
We all pay to go to school. This is part of the education. Please link to where you read 60 PSI fuel so we can make a correction and this doesnt happen to anyone else.
Good luck on the teardown. At least you didnt blow the bottom end out of the block.
