Jan 26, 2013 #1 J jk kelly Member Joined Nov 12, 2012 Messages 174 Im blowing my fuse under the dash that runs the fuel pump , it blows in a matter of seconds, any guesses
Jan 26, 2013 #2 GBGN1 BP Performance Transmissions LLC Joined May 26, 2001 Messages 1,680 Make sure the plug in for the oil pressure sensor isn"t grounding out on block
Jan 26, 2013 #3 J jk kelly Member Joined Nov 12, 2012 Messages 174 GBGN1 said: Make sure the plug in for the oil pressure sensor isn"t grounding out on block Click to expand... Where is it
Jan 26, 2013 #4 GBGN1 BP Performance Transmissions LLC Joined May 26, 2001 Messages 1,680 sending unit is on the lower front of engine on passenger side- 3 prong I believe
Jan 26, 2013 #5 H Hot Air E85 and S.E./Carolinas Moderator Staff member Joined Nov 11, 2002 Messages 3,102 Is the pump shorted out? Get out the volt-ohm meter!
Jan 27, 2013 #6 SS/GN Well-Known Member Joined Jun 30, 2005 Messages 2,892 Also check the fuel pump test lead behind the A/C compressor for going to groundBeen their Kevin
Jan 27, 2013 #7 J jk kelly Member Joined Nov 12, 2012 Messages 174 SS/GN said: Also check the fuel pump test lead behind the A/C compressor for going to groundBeen their Kevin Click to expand... Which one is that
Jan 27, 2013 #8 T turbojd Well-Known Member Joined Dec 27, 2005 Messages 1,983 jk kelly said: Which one is that Click to expand... There are 2 loose wires by the alternator, one is "green" thats for the tach, the other wire next to it is for the "fuel pump" I believe it's a gray wire.
