Tony,
I've been following this thread. You are obviously pushing too much air into the crankcase. Under non-boosted operation, the breathers should only let filtered air into the crankcase as the PCV valve takes air out. When the engine transitions into boost, the PCV valve closes and air should not leave the crankcase.
Under boost is most likely your problem. The PCV system doesn't work under boost, and the PCV valve
"Should" block boost pressure from entering the crankcase (the truth is most leak pressure into the crankcase.....how much depends on the valve and boost level)
Don't go jumping to conclusions about the source.........Test and find the source!
The first thing I would do is check the intake tract for boost leaks. I made a tool that clamps to the turbo inlet bell and allows you to pressurize the entire intake tract. You need to remove the rocker shafts. You will be surprised how many leaks you find at 20-25psi boost.
While you have the rocker arms off, do a very complete cylinder leakage test. This will tell you the health of the rings, valves, and head gaskets.
If you have a compressor, you can borrow my tools. If you don't have a compressor, you need to tell your wife that you
NEED a compressor to blow out the sprinkler system in the fall.
