BLURP 2-3 shift
hamer
when i give it GAS the car gets on it and goes through first to second WAAAAAAAAH shift WAAAAAAAH ... but when it goes from second to third its like WAAAAAAAH wawa WAAAAAH. thats a close as i can get it It seem to get worse when (under advice of a board member) loosened my IAC srew 1/4 turn (LONG STORY). its like a hesitation for a second and then its balls to the wall again. also when i let off the gas it acts like it wants to shift but doesnt. it lunges fwd slightly stuttering until i slow way down. it also shifts up at odd time, when im st5arting off or rolling at like 30-35 its a low gear then it hits and sounds like im running 50 bi\ut only going 30 or so. WHERE DO I START LOOKING???
I have no clue... How bout some backround on what we are trying to diagnois?
i really dont know where to start. bought car 3 mo ago and since have not really done major changes. Ive adjusted TV cable, changed fuel filter and PCV valve, new plugs cr43ts at .035 and 8mm MSD wires. Now, when i first got this car the guy said " it shifts hard but you can adjust it here.. and pointed in general direction of TB, so what did i do, before knowing anything i loosened the throotle screw a few turns. after i found this boiard i realized that i shouldnt have and have since corrected the IAC. My TPS is .043 and 4.6. I just adjusted the TV cable again Today and it SEEMS to have taken care of the problem. thats really it I run 93 octane and have the stock air setup which have plans on a cone soon. Let me know if thats enough
