SignUp Now!278cikiller
Bms hub
I have had one on my stage II motor for the pass 5 years and it a street car with no problems.
Squid4life I was anxiously awaiting an answer to this question as well since I have a BMS hub I was planning on running. I can't see your RPM being an issue, these motors are spun much higher than that in their original NA versions and Indy Lights I would bet. Is the RPM the only concern? Or overall longevity for many miles being driven added to it? I can't see it being a weak link, but hopefully someone with more experience will post up. Also, if the BMS is not a best choice to run, what is?
just out of curiosity how many miles have you put on it in that amount of time.
if not the BMS, i would run the BHJ balancer.
Steve
Quick question about the BMS hub... quick look at it shows it is a diff diameter than a stock hub and the windows and tabs are spaced differently than the stocker. For those running crank/ cam sensors still, do you just have to change the sensor location and the bms hub works like normal?
