deleonl
N.S.D.Q
- Jul 9, 2001
Guys,
Need some advice. I recently purchased a Bob Bailey’s two step and I’m having some issues. Does the two step only work with a stock ignition control module and coil pack for the GNs? I ask this because my GN has a 1995+ series II ignition control module and coils. See pic:
The issue I’m getting is that when I set my trigger to 3000 with full cut and I rev the car up and it will reach 3200 ish then start to pop but shortly after my service light comes on. If I back off and try again the two step doesn’t engage. I have to shut the car off and restart which will turn the service light off but I’m back at square one again. Everything is connected correctly per the instructions. I’m thinking the reason for this is the fact I have a different ICM and coil pack? Please advise..
