Bolt Kit
CTX-SLPR
Howdy,
Well assemblying a motor for a hybrid from scratch off of an non-LC2 foundation is tough. Its a 14 bolt pan 4.1L 484 block and I need to put together a bolt kit for it. Obviously with my custom front cover the bolts are going to be part Series II and part Stage II for that but otherwise, what are the bolt lengths so I can put a set together off of McMaster-Carr or simular to get the material and head styles I want. I couldn't find anything on Turbo Regal Web Site so no help there, so if there is a list there, can someone link it in?
Thanks,
RJC had some ss bolts for my motor- i would check with them-also look on ebay for bolt kits.
I bought a couple of stainless steel bolt kits from a vendor on ebay. I think it was "allens bolts" or "stainless bolts" something of that nature. search by "buick v6" and not necessarily "grand national".
Great kits. You may or may not want use everything it comes with, because it's made for standard non turbo motors, but will come with almost everything you would want. I think the only things I didn't use were the valve cover bolts and header bolts.
These were used on a stock block rebuild and my old stage II car.
