boost bouncing??
workingdan
I went to the track wed. and made a couple passes and my boost is all over the place. Any idea why it would bounce around so much? I have a adjustable waste gate and a grainger valve. What should my wastegate arm leangth be? Should it be long or short?
If it is too long, exhaust pressure can push the gate open and you loose boost.
I would say you want the rod just short enough to have to pull it with tension over the gate arm. Like 1/4", then set the grainger valve for desired boost.
