boost command?
mojilla
What switch operates the 3rd gear boost. If I have all switchs off, then my boost is 10 pounds in 3rd gear, even if my base boost setting is set higher. If I turn the 4 switch on, and adjust the trig button it will only allow me to turn boost up really high?
I must be doing somthing wrong. I do know it is wired correct because i have checked many times.
THANKS Joe
