boost control back to factory
wbzautocustomiz
Want my GN to go 11's one day
Have an aftermarket 2 stage boost controller on car and just want the stock one back on the right way still have all the factory stuff on hand any help to put back to original, where line go , tee, etc?
Factory wastegate solenoid should be hooked up like this.
Factory wastegate actuator hoses and T should be routed like this.
Make sure if you have an adjustable wastegate actuator, that it's adjusted to have just enough tension on the actuator arm and swing valve. Meaning you don't have to have gorilla strength to put the actuator arm on the swing valve.
That should get you back to factory.
HTH
Patrick
RUQWKNF thanks for pics and info will get at after snow we are supposed to get about 2 ft so I dont want my baby near snow or salt:biggrin:
