Twin Turbo T
- Jan 22, 2003
I have a innovative multi stage boost control. Does any know how to hook up the Co2?
SignUp Now!Originally posted by norbs
YUp, I have tested it last night, but i dont use co2 i use an air compressor and regulator set at 35 psi. When the msbc is set to 15 psi i get 16 psi boost. COnnect the top of the wastegate to the co2 (to the incresase solenoid) and the lower port of the gate to the turbo port (boost pressure) You could also use manifold vac, but it might cause a vac leak through the gate seal , they all leak.h
look here also:
http://www3.sympatico.ca/norbz/hookup-1.gif
