Jon Early
- Dec 4, 2014
Without getting too out of control with details, the inconsistent nature of this wastegate is driving me nuts.
My car has a Bowling Green Customs 3" downpipe and elbow with a TA49 turbo. The actuator is an unknown adjustable unit that came with the car. I removed the solenoid and tried an MBC, but currently have the hose looped from the turbo directly to the wastegate actuator for simplicity. I've confirmed with the mightyvac that it will begin to move the arm at around 10 psi when it's detached from the puck. With a whole bunch of preload on the actuator I'm able to achieve the 23 psi opening pressure with the mightyvac, and when I hooked it up directly to the turbo, it gave me the 23psi of manifold pressure I've been wanting.... for about a day. Now its stuck at 16 psi and pretty laggy.
This is only the most recent information as I've been battling this issue for over a month now. The puck is NOT sticking. I've made a couple changes to be completely sure of that. The hole which the puck arm passes through was drilled one size bigger, so the arm has a little wiggle room and won't get stuck with heat expansion or corrosion. The puck itself would would get stuck in the turbo outlet hole but I fixed that with a small amount of porting. The Bowling Green Customs elbow also allows the puck to crash into the elbow body. I fixed that too.
I found out that the actuator is an 1011-673 which is standard duty. I'm curious how they figure this, but I'm guessing that I'm just overpowering the actuator with exhaust backpressure? Even with the hose pulled off the turbo, 20psi is all I can make. I thought that preloading the spring was supposed to allow you to push the limits of the actuator, but I guess I was wrong. I thought that removing the hose would essentially send my connecting rods into orbit due to infinite boost too, but maybe not.
Am I on the right track? Should I be looking for an HD actuator? Thanks.
