boost control options.
cfish462
i just switched over from a ta49 and hooker 2.5 dp with deltagate to a pt61 with 3 in dp and i had a new, bigger tial w/g mounted to the header.
i was using the old atr manual boost controller with a turnknob you turn left/right for more/less boost and a red tab to lock it in place on the old setup.
anyways i got a used ramchargers BstC control unit and i was wondering if this can be used with the external w/g. everyone uses them with the stock style w/g so can this be done? do i need/should run both boost controllers? if the bstc doesn't work can the atr be mounted inside the car?, right now its on the header pannel. thanks
