87WE4BOOSTED
I NEED MORE BOOST!!
- Jul 14, 2008
Hey guys, Im running an external wastegate with an 18 psi spring, tuner style (top port of wastegated vented to atmosphere).The 18psi spring nets me 20 psi. When i place a manual boost controller in the mix, is the 18-20psi spring going to be base psi, allowing me to adjust up from there? Or, is the 18-20 psi spring going to be max psi only allowing me to adjust down with the controller? Trying to see if i need to stuff more springs in the gate to achieve desired boost levels. Sorry if this sounds weird.
Thanks,
Thanks,
