Boost Controler VS Adjustable Wastegate
S
Sleeper87
Guest
What is the better thing to do...Adjustable wastegate or get a boost controler? Is there any advatages or disadvatages between the 2....Thanks
Sleeper87
I would get both. You can make your own adj. WG for cheap. I have always used a bleeder valve ($12)to adj the boost and a adj Wg to set the base boost level
Sleeper87
You need both.
The Bst Contrl from Ramchargers takes thing to a new level in boost control, once you sort it out.
The best thing to do is not raise the boost until you have your problems sorted out and you put a new fuel pump on.
You can make an adjustable wastegate for less than $1 in parts and $6 dollars in tools (If you have a crecent wrench) using the instructions found on GNTtype.org.
