Boost Controller
My bad...he doesnt sell the MSBC-1 I thought it was the same as the BstC. I *think* Jack Cotton sells Innovative stuff.
Jason
FWIW
Jack does sell the Innovative unit not sure on price at this time tough :biggrin:
Thanks im still debating on msbc-1 or ams1000 that cal sells.they both sound impressive i guess it really comes down to price.
I bought the AMS 1000 from Cal. BAD ASS unit. My car wouldn't go down the track without it. I love the graphing feature and the actual controller screen is easy to get used to. There is none better. Pricey, yes but well worth it.
Personally if I was going to pick between them..... I would just spend the money and get the ams1000 espically on car like yours :) Il stick to a granger valve for my junk :eek: :D
I like cotton, but I must say the Innovative unit is a POS!
They have a new control unit that may help??
Mine sucks. :mad:
booost controller
Mine sucks. :mad:
every tryed it with co2
That won't help.
It's not the problem.
I have talked to guys that have tried that.
Innovative has accepted the fact that the control unit sucks, and they have a new one. But I'm not messing around with them anymore. :mad:
I tried almost everthing under the sun to get that thing to work right. Even Cotton has tried to come up with a solution.
I believe Sully is still having issues with this unit. He is using CO2.
Just my opinion, but go ahead and try one if you want. I can't stop ya.
If it comes down to price, the Innovative unit is much cheaper. If you want the one that works the best, the AMS is a much better unit. It will probably depend on how critical bost control is to your combination. I usually recommend the AMS for cars that are very traction limited (like Dusty's drag radial car). The Innovative unit should work ok on a big tire car or a lower hp car, where traction isn't an issue.
If you are running an XFI, I recommend wiring the AMS into the XFI. Also, the XFI can be updated to a diferent boost control strategy that has worked very well on a low 8 sec 6 banger
