- Jun 18, 2001
Long title, and I'm going to fill this post with keywords, too. So please excuse the obvious stuff in parentheses, I'm just trying to make sure this thing is easy to find for people searching in the future.
I've searched, and I'm not convinced, so I'm making a new thread.
I've got a third gear boost creep problem. Widely reported... with internal wastegate people. I have an external. I'm using a GrimmSpeed boost controller, which is essentially a bleed valve like the RJC or whatever you might fab up from the McMaster catalog. I hit my set points in 1st and 2nd (first and second) reliably, but in third (3rd) and up, I get creep from my 17psi target to 20 before I let out of it. I haven't stayed in it long enough to see if it stabilizes because I don't want to be arrested or blow the motor.
The combo is far from stock, but for completeness, I'll enumerate the high points here:
The MAP sensor, which is plumbed into the plenum via the vacuum block, is reading a boost creep in third gear. The boost controller is getting its reference signal from the turbocharger outlet. First and second are solid at 17psi (or whatever I set it to).
Would I rather want to tee the boost controller in with the MAP sensor, so they both see the same signal? Is it possible the turbo outlet is seeing steady pressure while pressure builds in the plenum?
- Comp 260H cam
- Ported heads
- .030 overbore
- PTE 5658 turbo with billet impeller wheel
- KB-style headers with external gate from buickgn.com (46mm gate, 10psi spring)
- Stock IC with MPE big neck
- Stock plenum and intake manifold
- aforementioned Grimmspeed bleed-type boost controller
