larrym
West Coast Newfy
- Jul 17, 2007
I run a turbonetics evolution waste gate I have been tuning the car and have got it running really well I'm on a quest for a 10 sec tip slip
My car spools quick, when I check my logs the boost fluctuates 1/2 psi and rpm about 65 in 3rd gear.
I found 2 exhaust leaks at the waste gate and hoped sealing them up would correct the problem but no...
I'm going the try it with just the spring no lines and see what that does. I have checked for other exhaust leaks and vacuum leaks all appears well. My buddy suggested new plugs as well thinks I might have a weak hole that only shows up under heavy load. Anything else I should look at? If it's fine with just the spring are these gates rebuild able?
I looked for a kit but found nothing. Green is RPM blue is boost.
