T
Turbo Dog
Guest
Previous owner of TTA #259 had vacuum hose on inside nipple of boost solenoid. On my GN it goes on the outside. When I moved it to the outside I get no boost over 10 psi. It went to 16 on the inside. However, it has an adjustible wastegate,which is turned all the way out. so, are the boost solenoids the same part on the TTA and GN? Which nipple should the hose go on? Thanks!
