Hopefully you guys can help me figure out why I overboosted and give me recomendations. First here's my setup:
'86 GN, 112k, virgin motor. New PTE 60 Turbo w/hd wg actuator, new Turbo Tweak 60# injectors and TT alky chip set for 22# boost. Home made single nozzle meth/alky kit. 3 1/2" maf and translator, TH 3 1/2" downpipe w/internal wastegate, into stock exhaust (no cat). Cold air kit, big neck stock ic, Stage Right brake, stock converter for now. New kirban valve springs, stock unported heads and cam at this point. Hot wired fuel pump. Scanmaster.
It's been running rock steady 22# on the street with 93 octane, 50/50 water/meth spray and stock exhaust. Zero knock retard.
1st run at the track, uncapped dump tube, sprayed 100% Meth. Glanced at the boost gauge at near the end of the 1/4 mile....Pegged past 27psi!!!
I hit return road and felt it skipping. Scanmaster showed 13.4 KR.
Why the overboost? Chip problem? Solenoid? What should I do to correct it, besides pay more attention. I'm going to install my Caspers audible knock alarm. But I really need to figure out why the high boost. wastegate actuator is backed off about as far as possible and still have it seal.
It blew out the head gasket fire ring on #3 at the top into the crankcase. It never pushed to coolant Compression test showed 150+ on all, except #3, which was zero.
Also, I'm not sure if I'm going to do both gaskets, port the heads, roller cam install, maybe even pull the motor to change the converter and make the whole project easier. Goal is low 11's or quicker.
Searches show only confusion on headgasket choices. I think I'm going with the stock GM graphites it had. It looked great except for the clean tear from the boost. What's another 2 grand at this point.
Sorry for the long post. Wanted to get it all out there. All suggestions are appreciated, especially on the overboost issue. Don't want to pull this bitch more than once. Thanks
