turbowrenchhead
Drive like you stole it!
- May 25, 2001
I have been dealing with this issue since last year. I get up to 12 to 14 pds of boost and the gauge drops and i loose power untill I let off and reapply the throttle. It will stay steady at half throttle or so then when I put the throttle the rest of the way down it instantly disappers. Last year I wired the wastegate puck shut and it didn't disapper so this told me that i must be sticking inside the hole in exhaust housing.
So last week I had an external wastegate put on. I have steady boost with no controler on it but it only runs 8 pds of boost. As soon as I put my grainger valve on it same thing. I tried my air regulator in place of it and same thing. Then I plugged the outlet off the compressor housing and ran the controler to the map sensor line and I also replace the small lines with 7/32's vacuum line. Same thing. I cranked down my BOV and no change. Right now I took off my BOV and put a plate in place of it. I did this last year with the BOV and had no change. Now I'm grasping for ideas as to what could possibly cause this strange problem.
