- Nov 30, 2009
I finally got the car running , no leaks , solid oil pressure ( #28 @ idle ) , coolant @ 160-170 max . I took it to Norwalk last May and ran 12.01 @ 118 but my boost was solid at 19 psi the whole run and I'm on E85 & chip burned for 25-28 psi. I talked to Bison at Longhorns while we were there for dinner and he said I'm losing exhaust somewhere . As I expected he was right . I pulled the downpipe and checked waste gate puck alignment and it wasn't completely covering the hole on the turbo . The puck is 1.5" in diameter and it's about .1" short to one side , also there is in & out play on the shaft the puck is mounted to . I've got room to oval out the mounting holes to shift it over . If it still doesn't cover the hole what are my options ??
