Need help have a tt chip burnt for 16 17 psi have a adjust pressure reg, fuel pump from kirbin throttle enhancer, 160 therm,scanmaster, adjustable wastage, kNock guage and
boost.I set the boost at 10 psi with solenoid unplugged I set preasure at 43 vacation off I'm am getting kNock I set preasure higher less kNock my blm was at 143 now with higher fuel preasure blm is at 123 what is the max fuel preasure reg can be set at the higher I go my blm goes down also I get less knock so when I plug in the solenoid I should get the boost chip was burnt for. Also stock injectors going to upgrade injectors what do you recommend
