trading t/a
I'm Angry!!!!!
- Aug 6, 2001
I am having trouble with attaining boost. I've posted about it in other threads. Today I decided to do the wrong thing and hope it didn't blow anything in the process. So I couldn't get anymore than 13 psi. I checked the wastegate rod(plunger moves in and out), checked the vaccum lines(all good), checked the puck(moves freely), so I decided to take the vaccum line off of the wastegate plugged it with a screw(for now) and did a run. Spooled a little quicker this time,got a good hazing of the tires on the 1-2 upshift, hit third got 8.0* of knock at 14 close to 15 psi. Pulled some timing out with the trans+ and did another. Same thing almost 15 psi(14.? close to 15 on the gauge) with 1.2* knock @660mv.
Now my question is, isn't it supposed to overboost? Without the wastegate relieving the pressure I thought it would go sky high! I maxed it out to about 110mph and couldn't build anymore than that. Any suggestions? It runs like a rocket from idle to max boost but I cant get anymore out of it.
Still kinda choppy at idle and blms are low but it's coming along.
Thanx for any replies.
Pete
Pete
