turbodave231
Moderator
- May 24, 2001
I ran into a situation in BG where my WB sensor supplied with the BS3 system went south. The car ran like crap till I figured out what was going wrong.
Not having a spare sensor, I called Precision Turbo (where I purchased the system) to find out what available sensor(s) I could use. They told me that I had to get the sensor from them and no other sensor would work. The sensor that was supplied with the system had the number ground off (Thanks a pantload for that one guys ) so I couldn't cross reference the sensor and find out what OEM sensor was used when the system was developed.
Stuck between a rock and a hard place, I found a VW sensor (same as the LM-1). With the simple removal of the harness lock, the LM-1 sensor plugs into the BS3 WB harness.
I was concerned that the calibration would not be correct, but luckily I have an Innovate LM-1 and a 2nd bung on the DP already. The VW sensor correlated perfectly to the LM-1 system.
Does anybody know what the BS3 sensor Bosch number is? Or should I just keep using the VW sensors? I can buy the correct harness side connector to mate to the VW sensor. Maybe I'll just build a pigtail to accomodate either sensor.
BTW, the car ran great after the VW sensor was in place. All the data log made sense again and the car ran hard......just need to train the driver how to cut a better light .
Dave
Dave
