“Bowling green custom downpipe elbow”
TireFryer
Boost Loading......
What is this? How do they flow compared to a normal terry Houston style downpipe?
I have one... Kinda collectors item but fits well under a stock turbo heat shield. Flow is decent but most go with a Terry Houston down pipe or that style. I wouldn't be afraid to run it. Make sure it's a 3" they make 2.5 and 3" I believe.
This is a Bowling Green Customs 3". I'll sell it if you are interested
The BGC pipe flows well and is neat that it will fit under a stock cover but is heavy compared to a Houston style pipe. I have never seen a 2.5 version with the large cast elbow.
Do a search for ported elbow or 2.5" down pipe with board member ungn.. you'll be surprised.
I use .one....I unfortunately received mine near the end of there run as a business and it had a hole in it ....sent it back and the same issue. Being a fabricator and welder I repaired it with inconel welding rod then ground off he BGC . LOL . But I like it and had no further issues. But you will need a down pipe specifically for that elbo.
I found a BGC for $400 with downpipe. My TH style one is screwed up, someone milled the surface like 25mm and the puck jams open and I just need to get it back going for my wedding. It also won’t seal without the downpipe being almost 1/2 inch off the housing of the turbo because of the milling. I have the stock one I can run temporarily. I would rather run a TH style they’re just more expensive to replace.
Do you like it? How much power are you making? I like the idea of the nostalgia of it, but would be worried about the flow compared to a TH style. Obviously it won’t be as good but it looks like it has decent flow. I also like the stock style downpipe, as it fits very nice compared to the one I have currently
Running a TA engine with a 62/65 turbo with about 500 hp....no issues with flow. Yes I like it. After reviewing your nice combo you will have no issues in my opinion. Regards
I have a shiney brand new 6262 to replace the old te62 and a new converter too👀
The bgc 3 inch is more than capable of flowing 10 sec power
I would jump on that 200 offer😉
Already in the process. Ive seen on forums of people running 10's with a stock elbow and downpipe. Sounds like the stock elbow is the main issue as its a horrid 90 degree bend off the turbo exit which is horrible for flow. Plus having a cool piece of buick history on my car is always neat
BGC 3" was my favorite down pipe, went in the 10's with it like 30 years ago. It was the only pipe that used the stock bolt and spring so it had some movement to prevent from cracking. I can see you did not install the springs.
BGC.... WOW! What a fustercluck that was!!
John and his wife left a trail of dead and wounded before they were "run out of town"!
Really? Never heard of that, that sucks. I disappeared for a while so probably screwing people during my absence from cars. But at there prime, in my opinion they had the best go fast parts in the 90's.
