Braces
bilt2run
frame braces(front).. the two that triangulate the frame. Also would like to have the one that runs under the core support.
I have the one that goes under the core support. I took it off to install a fmic.
50 buck shipped.
Scott
Part number 6756??
The link only goes to kirbans front page.
Yeah, that is a tad different from the stock 83 Grand Prix part.
I like the stock GP one because it huggs the core support so you can still run a front mount, appears the Kirban one hangs down quite a bit, would also hit the stock shroud.
BW
the one i got fits tight against the frame then the swaybar bushings go on top of it and the bolts go through them it fits right above the factory swaybar
Quick6'n'-K.C. said:
Part number 6756??
BW
Yeah that's the one. It doesn't hit the shroud. I didn't know that was a gm brace. Tim took off mine so he could hug the core support with front mount pipes.
Scott
