Braided Stainless Turbo Oil Feed line..
TType84
cookin with propane
Yea I think i should replace my line with a new line.. dont, however, know what kind of AN fitting im gonna need for the bottom .. cause as of right now i cant see where the line goes.. how much total shoudl this run me? do any vendors sell lines already? thanks guys!
I just had to replace mine, but I felt better using a hard line rather than a "soft" line. I used 1/4" brake line and the fittings that came on it fit perfectly into each receiver end. If you remove the lower radiator hose from the water pump, the bottom fitting is accessable. I bought a 40" length and cut off about 8".
I used teflon braided line works and looks good. Use #4 line. I couldn't find a fitting to fit into the block ( the one the oil psi sensor fits on ) It's a 1/4 pipe thread. I took the line to parker store ( hose/fitting store ) and they pressed on a high pressure fitting. I used a 90 degree lbo at the turbo.
Dave85
