Brake accumulator ball replacement procedures
kels87gn
Juust like the title says. Does anyone know or can post how to replace the accumulator ball on the power master system?
Pump the brake pedal 15 times, it should be rock hard
Remove and replace
Done
Key off when you pump the brake pedal
Sent from my SM-G900V using Tapatalk
Thanks. Once replaced is there a need to bleed the brakes?
We would have told you to bleed the brakes if you had to during this procedure. If you haven't flushed the brakes in the last 5 years, then yes bleed all your brakes.
Not needed to bleed the brakes if you just swap the ball
Thanks a bunch. I'll order from Kirbans Monday. They sell what looks like the same one that Kirbans sells on eBay but there is no real price savings. I appreciate the help and will let you know how it goes.
