Brake balance with Wilwood rears
turbodave231
Moderator
I know this isn't the brake forum, but I figured I'd get a better answer from guys who are using race style rear brakes.....
Will I need to install an adjustable prop valve with a Wilwood rear disc setup or can I just eliminate the stock prop valve? (I'm using the stock front discs)
Dave
Dave,
I run Aerospace rears with the stock prop valve removed and a Strange manual MC. I then set the bias with a Wilwood adjustable valve. I can make the rears do what ever i want. From very soft to violently hard in application. Lots of adjustment.
I used wilwood manual master cylinder and adjustable prop valve with the stock prop valve in place. Still have stock front brake for know. Works great.
