I should get my new Powermaster System tommorow. Once I get it installed I will need to bleed the brakes...
I have never done this before.
I have heard of bleeding the brakes at the 2 fittings on the Master Cylinder. Is this an OK way to bleed? I dont want to mess with the brake bleeders. They look pretty darn old. Do I Pump the brakes with the key on or Key off while I fill the resivoir with fluid? Fill then pump brakes? Also how much fluid will I need?
A step by step from someone who's done this before would be of great asistance.
Thanks Much!!!
Thanks Much!!!
