BlackMetal
- Sep 29, 2005
Let me get right to the point. I hate bleeding brakes. With two people I guess it isn't that terrible, but alone in the driveway... no fun.
This spring I am doing an LS1 front brake swap and possibly converting the entire system to vacuum, aka mucho brake bleeding will need to be done. I could take the car to work and try to do everything there where we have an electric brake flush machine which effectively bleeds the air out of the system, or have access to compressed air to use a mityvac, BUT I will most likely end up working on my driveway just so I don't get stranded at work if something breaks/goes wrong etc.
So on to my question. Are any of these brake bleeding tools worth it... or gimmicks that leave air in the system anyway.
Speed bleeders. Seems straight-forward enough. Bleeder screws with a check-valve so you can pump the brake pedal yourself and not have air enter the system. Do these actually work or leave you with a spongy pedal?
Pressurized fill bottles. Connects to the master cylinder like the standard "gravity" bottle that refills the master cylinder automatically while you bleed so it doesn't run dry. Except in this case you operate the hand pump a few times to create pressure and then crack the bleeders... so I guess it's just an alternative to getting in and out of the car to pump the pedal.
Aside from the items I'm mentioning I'm open to any other suggestions that would make this task less annoying.
