turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
Leo you are gonna be real happy after all of this and the troublesome sealed bearings in those spindles start making noise. Hope it works out for ya tho either way
SignUp Now!Leo, did you install the s10 brakes when you did the 87 swap? Or did you install the S10 brakes later (which I think is the case). I wonder, if it's a high pressure issue, if you could restrict the pressure line??
PS..Go to bed, but first wish me a Happy Bday : )
Luckly I was able to get @ a steal on a new set of GM bearings that I have setting on shelf.
Leo, I think I have a 3000lb gauge that you gave me years ago...If you can't find yours then this is probably it!! LMK if you need me to send it. And yes I need that number.
Did you figure out anything Leo??
Interesting problem and an even more interesting reason. I never would have thought that the excess pressure would deform the seal so that it didn't pull back the piston.
The reason I posted is that my understanding of hydroboost systems is that they use a 1-1/8" bore M/C. This provides good volume but at a lower pressure.
Not sure what bore M/C is on the car now, but a 1-1/8" M/C may be a better choice then running a pressure reducing valve.
RemoveBeforeFlight.
I got the return call from the GM engineer. It looks as if the 1500 psi is more than the S-10 brakes were designed for. The square o-ring it not deforming (I should hsve worded it better)--it is being twisted outward toward pads as it is designed to do. It is returning to its original shape as it is supposed to do. The excessive pressure is pushing the pistons a small amount farther than they should go. The square o-ring is returning back to its original shape as it should but since going too far this leaves the piston a little short of releasing pads. He also mentioned that they design a brake system for a certain amount of caliper flex @ a max. pressure. I am probably getting excessive caliper flex which would contribute to the problem. He did also mention master cyl. bore size. I have a list of ? and plan to call him first of next week. This all makes sense as I can free brakes with screwdriver--drive car normal --raise car and brakes are free--power brake car --raise car and they drag. Thanks to all who have helped. I will keep posted.
Lee, post a link and/or part number for the valve please. I'm planning on doing the conversion this summer.
any updates Lee?
