SignUp Now!The Motor/pumps Wear Out And Fill With Brake Fluid. This Shorts Them Out. The Accumulators Wear Out, Also, And Then The Pressure Switch, Too. It Seems It Is Always One, Or The Other, That Needs To Be Replaced Every Year.
DUH! I knew that. Just being stupid today.What I Was Refering To Is When The "seal" Between The Pump And The Windings Fails, The 12v Side Will Fill With Fluid And Short It Out. That Is When The Fuses Keep Blowing.
Oh Yea? Sounds interesting. It would be good if you can offer a quality rebuild at a competitive price. P/M prices aren't too bad these days, but they are getting higher.We Recently Found Some New Pumps For The P/m, And We Can Rebuild The Original Unit, Using A New Pump. We Need To Acquire The Accums And New Switches, And Then We Can Offer A Quality Reman Unit.
Oh, I agree. It's just that initial costWe Like The Hydroboost, Because It Needs No Vacuum ,and No Electrical Connections. It Just Does It's Job, Reliably. If The Engine Is Running, Usually When You Are Driving, The P/s Pump, And The Hydroboost Is On The Job.
