Brake light help
dsapper
High everyone, I have an issue that I'm sure will end up being a ground issue (arent they all) but wanted some opinions and maybe some advice on where to start.
My brake lights are having issues. The third brake light works fine and the left brake light works intermittently. Yesterday neither of them worked (third still does). Also the front blinkers work fine and again, intermittently, the rears dont work.
All the running lights work. Any advice on where to start?:confused:
For future searches I found the solution
It was the turn signal switch. Apparently the brake lights run through those?! Either way its fixed and works great
oh boy i remeber this one. yeah it wa the turn signal switch.... i replaced it and all worked fine. so i agree with whats stated above its the switch.
