Hunter,
The pads I have now came from AutoZone, their RayBestos or what ever is there high end pad. Cann't recall, it has been about a year. Same deal as what the others have said, ask in a different way. When I first got my TTA there was not a 3.8 listed anywhere in 89 at my local Autozones despite what everyone said. A few months latter, bamo, back in their system. If you still have no luck drop me a line (brent@brentg.net) and I will get you the part numbers I used.
BTW, while you are under there you may want to do what I did and swap in a set of Earl's stainless lines. They cost about $90 but where worth it. At a minimum I would get a couple of large bottles of brake fluid and change out the old factory stuff. My car only had about 27.5K at the time but the brake fluid looked like hell. I used the DOT 4 Valvoline Synthetic.
And one more BTW, keep an eye on the back calipers. One of mine started to stick after I did the brakes all of the way around. The front may be prone to it as well. My understanding is the vetts had the same issue. You get a little corrosion on the piston which ends up causing it to stick in the aluminum bore. No real worry, happens every once in a while as I understand, just something to keep an eye out for on your first few drives.
Brent
