87 WE2
- Jun 28, 2002
(2) Vacuum brake setup’s - master cylinder & booster only. (No pedal)
Set of low mileage stock size SSBC vented rotors low mileage, no bearings, or seals.
set of stock rear shoes low mileage
set of used good rear wheel cylinders
set of used working front calipers with pads
set of used front flexible brake lines, caliper to frame
set of good used caliper bolts
set of good used stock rotors, with bearings, hardware, dust caps
set of brake backing shields behind rotors
All brake stock steel brake lines also available for entire chassis
4 new in the bag caliper bolts
new set of Wagner gold front brake pads new in the box
