Brake Pedal for Vac. Brakes?
TacticalGN
I've heard you can use the orginal power master brake pedal when converting to vac. brakes. It just has to be drilled. Is this true? I would rather do that then replace the whole pedal when converting over. Thanks in advance.
I've got a complete vac. boost system to sell if you haven't already got all your parts
Thanks. But I already have most of the parts. I just need the correct vacuum block. The one with the extra port. I believe they used them on the TTA. I've seen them on Ebay from Earl Brown, most likely going that route.
