brake upgrade
Stock g-body brake hoses with new crush washers here. Works great.
Did you move the line from the original position?
I am test fitting my set up and if I use the original line and leave it in the original mounting bracket on the frame the hose will hit the upper control arm and frame?????????
No, the rubber lines attach to the frame mounted hardlines in there original position. No mods needed. The fittings on the caliper end attach to the caliper so the hose is nearly perpendicular to the caliper, if that makes any sense. All bolt on though.
No clearance issues. When I first installed the ls1 setup, I had braided hoses and those both broke from being pinched between the spindle and control arm. Switched to oem hoses in a pinch and no issues since.
