Brakes; after line lock install
1kwick6
after i installed bigger wheel cylinders,soft rear shoes,line lock ,and about everything new ( brakes are great)only thing is now the brake light comes on when you hit the brakes hard and you can hear something clicking in the proportion valve; and also the light comes one when you engauge the line lock what gives am i the only one or did i do something wrong??? brakes work fine as long as you just use them like normal.
brake lite will come on when/after line lock is engaged.....never heard any noise in the prop valve?
i have the same exact problem. when i hit the brakes hard i
hear a click noise and the brake light comes on for a second.
then when i turn my line lock on the brake light comes on.
after i release the lock the light is still on until i touch the
brakes. i really don't know?
noise sounds like the plunger coming out ,you know when you bleed the brakes and you go to the floor and it clicks that noise. only deos it if you hit brakes quick
