Whiteturbot87
- Jul 10, 2016
I would not crank the engine with just the plug wires pulled off. if the coils are trying to fire with no plugs attached the voltage spike is not really good for the coils.
the best way to disable the engine from starting if you want to crank it over is to unplug the crank or cam sensors, or unplug the ignition module.
Anyway, I agree with most of what these guys are saying, you want to figure out what you have, and low oil pressure is not a good thing. If the engine is really just 6K old, then I have to wonder who did the work, and what the bearing clearances and pump clearances are.
If the oil pump was reassembled with a new gasket, it likely has too much clearance which will affect your idle pressure. Easy fix there.
But, one last thing..... What kind of oil presure gauge are you using? I had my share of bad luck with gauges, and don't trust any of them any more.
Where are you located, likely there are members nearby that can lend an eyeball to the diagnosis.
Bob
Im in palm desert california, maybe theres someone nearby. And how should i go about checking clearance on my oil pump? Also im using VDO electric gauge, any ideas on how to hook up a more reliable mechanical one?
A decent mechanical gauge will cost you in the range of 70$ from summit.
However for test purposes you just need a mechanical gauge that is not damaged and a way to connect it to the brass tee at the turbo feed from the block where your electric gauge sending unit is....If you are not able to come up
with the needed fittings and tubing for a temporary guage you may just want to make the purhase from summit or jegs of the mechanical gauge.
Checking the oil pump end clearance is a PITA with the engine in the car.......
You will want to rotate the engine and line the timing marks up....this will help with reassembly.
NEXT you would have to remove the cover plate that is held on with 6 bolts and
then you will puke oil every where as the pump drains out.
Then you will need to remove the cam sensor noting its position both where the wires are pointing'
and take the cap off and note the position off the window in the rotor for reassembly.
Then after cleaning you will need to get a plastigauge set that goes up to .009 from summit IIRC
then put the plastigauge on the bottom of the pump gears reassemble and tighten to crush
the plastigauge......then remve the cover again and comare the crushed plastigage to th the strip chart
provided in the kit.
Or the the best way is in you have access to machinist tool you can use a depth micrometer and then a micrometer
to measure the crushed gasket and do the math.
But I have never done one in the car and I do not know if you can use the depth mic in the car......
Then after that is all done you have to pack the pump and gears with vaseline or wheel bearing grease put the
pump together then prime the oil system and then go through the cam sensor setting procedure and then put it all back together.
..............Like I said a real pita to do in the car............
yeah that sounds like alot and a whole lot more than my knowledge of these motors, ill inspect everything first rockers bearings etc. alsoo ordering parts for a temporary oil guage ill install at turbo inlet line, just to make sure my readings with the electrix one were accurate. After all that i will tackle the pump, updates coming.
thanks for help ill attach a couple pictures of my pump and motor. Im inspecting rockers and bearings first then installing a temp mechanical guage just to verify the 9-10psi at idle then ill tackle pump. And i dont understand are you talking about a thinner gasket beVDO is decent, GlowShift sucks
there are some oil pump experts on here that can go into real details. But the first question is whether the front cover is stock GM, or aftermarket and whether it has a high volume kit or not. Post some pics of it.
To set clearance with out removing the front cover, you unbolt the oil filter adapter and lay a straight edge across the face of the gears to determine if they are flush, sunk into the pocket, or protrude. then select a gasket that sets the assembled clearance at "almost nothing". Selective gasket kits are available from TA performance. You can also add a high volume kit which will help your pressure and let you run lighter oil, once you are satisfied that the engine is basically healthy. (note that my engine is this way, with the high volume kit I have about 10 psi at hot idle with 10W40).
And, since nobody mentioned it, if you have a conventional flat-tapped camshaft you need to run conventional oil with ZDDP additive, or the cam will probably fail on you.
Bob
Bob
Thanksfor advice im setting up a temporray mechanical gauge to verify 9-10psi then checking rockers and bearings, last ill tackle oil pump if need be. Did you mean a thinner gasket between pump and block or adapter and pump.?
