Whiteturbot87
- Jul 10, 2016
You can use a 1/4-20 allen head bolt about 1/2" long from Ace hardware to insert in the spring on the cap end. That is what Kenne Bell used to use. It will not increase oil pressure at idle, only above idle pressure.
So i got that allen head bolt in that size and now im just waiting to pickup my new filter but i wanted to know where the oil spring cap is, and if im drilling into it? How does the bolt work does it adjust pressure the more its turned or should i drill it in all the way into wherever this cap is? I assume behind or to side of filter?
