just put new t63e and front mount on tonite. have brand new motor too with less than 1000 miles on it. went out for a test and tune and only have one problem. any boost over 10# and the car bucks and sneezes as if i let off of the gas. I mean falls on her face. also seems to stall alot if i get off the gas quickly. I have a 9in non-lock up art carr. I am running an open loop thumbwheel chip with 18 degrees of timing and 50# injectors. I had the feul pressure set at 50lbs with vac off for safety.any help with these problems would be appreciated.
