mikewest_08
- Sep 8, 2012
SignUp Now!My engine builder suggested that I drive put around 1500 to 2000 miles to break my engine in. Other people disagree saying it is not needed, but I will follow his recommendation because if something were to go wrong I can say I have followed your directions to a tee. I've got about 1000 more to go. This reason so the piston rings will set properly. However, I a couple of 10 to 15 psi, mid throttle he said wouldn't hurt. He said just don't go all out until the 1500 to 2000 mark. I will err on the side of caution and put the 2000 miles on. So far since getting my engine rebuilt, all I have done really is cruise. No place where I live to light them up. However, with an HD actuator it is tough to keep the boost under 20psi, so I have to watch it. Chip is a street chip burned for 18psi. So I probably won't get my 2000 miles up before winter. Once the 2000 mile mark is hit, I'm sending my chip to get burned as an alky chip and running 25lbs next summer. Can't wait. The only problem is I'm going to need some a bigger tires. Some MT DR Pro's.Motor is fully assembled, setup and primed? If so, start it up, check for leaks, after reaching operating temp hit it with boost a few times to seat the rings...this procedure assumes full roller motor. Depending on engine builder you may or may not need to change oil. Cut open oil filter and check for the bad stuff. Install new filter, maybe new oil too.
HOLD YOU PHONE SIDEWAYS !
What kind of rings did you use, I can hit the boost on engine, but my engine builder told me to wait until I got 2000 miles on my engine before letting loose. So I have 1000 more miles to put on it in the spring before I can turn up the boost.I just got done building a new 4.1, and am wondering what's the best way to break it in? Also is it common for a double roller cam with hydraulic lifters to be a little tickie?
Never mind.2000 mi for a break in???
Sounds to me as tho the "builder" is only delaying the inevitable....A tear down.
As for no place to " to light them up"...As long as you can put some load on the engine, there's no need for that.
Have you cut the filter open?
How about an oil sample?
