Crammysauce!
- Feb 23, 2007
Hello again - so I am finally running my engine to break in the cam, and after about ten minutes of running, the oil pressure was staying at around 17-18 psi. This is at 2000 rpm. Is this low, or am I just overreacting? What are some oil pressure psi numbers I should look for under normal operating conditions? Idle, driving, WOT, etc. Thanks!!
